After I enter edit mode, I’m having trouble being able to use the move tool. When I select it it will stretch of squash the mesh instead of moving parts of it. Any idea how I can fix this?
I should probably include that I am using Zbrush 3, the 30 trial. I wonder if anyone else has had this problem with the trial?
use the move brush now, otherwise you’re using transpose, check the wiki for further info.
yes, thank you
I refused to go to sleep last night until I figured out the problem. I finally found it at the end of all the zbrush tutorials on the official website. I don’t know why they would make an interface so close to max and maya and then change something as inportant as the move verts function. I guess I still have alot to learn in zbrush. But thank you very much for your reply.
