Problems when I am trying to use Surface noise UV
Every time I am trying to use Surface Noise UV on my meshes ZBrush 4.7 crashes. I have enough memory in my system, so this shouldn’t be an issue. Any ideas?
I was getting this too, then it stopped. One thing you might want to try is to see if it happens in the 32bit version. Might be more stable maybe…?
Seán
I had the same problem even with 32-bit version. When I contacted Pixologic Support I was advised to delete ZBrushData folder, and it helped.
In some cases the only solution is to reinstall Zbrush.
