problems using zproject brush to texturepaint
hello. I am following a tutorial where you are shown how to transfer the texture image on to your object. I was instructed to select zproject, choose the texture image, use the transpose by selecting the move tool, then the edit tool. I set the option to RGB and when i color transfer the texture, nothing happens. What is going on? please assist. thank you.
Hello I am using the z project brush to texturepaint and I am having some problems.
After dropping the image to the canvas, I then use the z project to sample the texture. nothing worked. The funny thing is that when I moved the model over the image in edit mode I was able to transfer some texture which was of no use. are there any bugs associated with this plugin? please help.
zProject isn’t a plug in.
Could you show the steps that you’re using to try to achieve your result?
Which version of Zbrush are you using?
This particular feature is currently disabled in version 3.5 as it uses code that has already been rewritten for version 4. The feature will return with the next version.
One thing you could do right now would be to use ZAppLink to send your model to Photoshop and then clone the details onto it there.
1 copied my image and dropped it on the canvas using image plane 3
2 using zproject brush
3 import my object drop to the canvas
4 use the move tool to operate the transpose tool.
5 switched on the edit tool to transfer the texture…nothing happens
I am using version R3
Incase you missed, aurick answered above. Currently, in ZB 3.5 R3 it is basically disabled…I only just found this out today after watching a zillion tutorials and trying it 30 different ways only to come to the conclusion I couldnt get it to work ROFL Glad to see it confirmed here though or I prolley would have chalked it up to something I just didnt understand and would have given up on it…now I know Ill have to go about it a different way or wait all patient like :slight_smile:
thank you for that. I am using the zapplink and it seems to be working ok. Although I am finding that my system crashes whenever I return back to zbrush from photoshop.
