Problems manipulating CurveTubes
Hey im finding it really hard to move around the curves to suit what I need. Its like no matter where I pull the curve it will pull away from the anchor points. Its as if the curve has a fixed length and pulling any point affects the whole thing. Basically all I want to do is to set 2 anchor points and to be able to manipulate the curve around the two points. Am I missing a setting or something :S?
Thanks in advance
Once you have drawn the curve you can stop it moving by turning on Stroke>Curve>Lock Start and Lock End. You will then be able to adjust the curve the way you want.
ty very much !
