problems loading an Image on Canvas
Hi Guys
Please help me out here…
am using the LOAD IMAGE function on the texture palette to paste my reference on canvas so i can
sculpt as i view my reference but my Ztool keeps intersecting with my ref/canvas so my ztool is obstructed behind it…
and i can’t work!! How can i fix this? PLEASE HELP ME OUT
Here’s what i mean, wen i load my Polar bear ztool its fine, but wen i rotates it, it gets obstructed!! (view attached image)
under> texture > image plane > load image will apply your reference image to a plane 3d, append your model to it in subtools
click on it and sculpt your model.you may have to scale - size image plane with model - you can save your model this way to continue later and delete
it when done:+1: zb 4r5 also has app transparent now with image in backround also in lightbox there are grids which you can edit near the bottom of the draw menu - cheers
Heyy Gary
Thanks alot for your reply
Appending my ztools to the reference /3d plane is a good idea but i dnt really like the fact that wen i rotate my ztool my reference will rotate with it…
Am still new to zbrush so i kinda find this a distraction in a way… (am still used to my ref staying still, u knw wat i mean)is thera way to make my image plane stay still…perhaps utilizing the layers palette to make separate canvases…i try but failed so i let the zbrush pros gv it a try :wink: ur efforts will be very much appreciated…
NB:am using zbrush4R3
Draw your ztool on the canvas and enable Edit before going to Texture>Image Plane>Load Image.
Dude u got it spot on!!
thanks alot mate…i cant believe all the trouble i went thru was just because of the oder of doin things…its not fair
thanks zber2 i appreciate u taking ur time helpin out…you too Gary :slight_smile: cheers good people.
Happy zbrushing
