Problem with Wacom Bamboo
Problem strange enough - when you draw a feather does not work modifier ALT. It turns out that I can draw only either in Zadd, or in Zsub. And the sign on the cursor “-” on the cursor appears, but as soon as concern with a feather it all the same disappears. With a mouse all normally works. The most ridiculous that the elastic band on the handle works absolutely correctly, at an alto subtracts. In options of any adjustment of a feather has not found, in the tablet software only pressure.
Help, if who uses = (
I hope for your help!:slight_smile:
And the second question - whether exists any software, for storing appointed to a tablet and the handle of keys directly to the certain program? In AdobePhotoshope - one keys, in Zbrush - accordingly others? In software Intous there is such function, at Bamboo unfortunately is not present: (
Make sure you have the latest drivers installed for your tablet. Also, in ZBrush, insure that under Preferences>Tablet>Use Tablet is enabled.
The problem really was with drivers. After installation of the newest all works perfectly.
Many thanks for a fast reply! =)
