Many thanks for the file. I’m not yet entirely sure why this is giving problems but I do have a solution:
- Save out your original model from the Tool palette as a ZTL.
- Restart ZBrush and make sure the new document is a good size - something like 1100 x 800.
- Load up your model through the Tool palette and put in Edit mode.
- There’s masking on the body and the tail. You need to remove this before operating Transpose Master in ZSphere Rig mode otherwise it will cause errors.
- Proceed with using Transpose Master.
EDIT: I found the problem. You have more than one document layer and for some reason this is affecting how the ZSphere rig is displayed. Deleting the layer will solve the problem. I will bring this to the attention of the development team.
[attach=260878]TM_error.jpg[/attach]
HTH,
