problem with topological brush
Hi Everibody!
I need some help with a function ZBr4. I want to use topological brush to create new topology on a POLYGROUP. The problem is that by creating this new topology, is reversed … make good topology, with a new POLYGROUP, but is backwards.
I’ll fix this problem using tool> Display Properties> Flip, but think it should be fine directly. Ther must be a way to make it right in the “alt+click” step.
Do you know what i´m doing wrong?
Thanks in advance
Don’t alt-click for the final step just regular click. Alt-click will invert the faces.
Great!
Thanko you Mentalfrog, it works perfectly:D
