Problem with the selecting tool
Hi all!
I have a problem when using the select tool. If i try to use ctrl+shift to select parts of the mesh in order to hide/unhide the cursor changes to the lasso tool but it does nothing :frowning:
If I use only ctrl for masking i have no problem but if i use ctrl+shift nothing happens. A couple of days before worked fine but now it doesn’t, any idea?
Thanks in advance for your help!!!
Which version of ZBrush are you using?
I’m using 3.12 in winXP
