Problem with the Matcap
Hi All,
I have a problem with the matcap,when I switch from the Redwax clay to the
LBrouwn clay the object look not good (example) can some one explane me what the problem is…Thanx…
Somehow you’ve partially filled the model with the red wax material.
Select the FlatColor material. Make sure that Draw>M is active. Then press Color>Fill Object. This changes the model back to the default behavior so that it changes to whatever material you select.
Thanx Aurik, every day we learn some more… :+1:
