Problem with the Layer brush...
Hi people of ZBC,
I am relatively new using the ZBrush and I have a little and common problem for the most of you but big for me…
How can I intersect two passes of the Layer brush but without seeing the proper intersection? I mean, the intersection at the same high level…I post an image to be more graphic. I hope you understand me. Thanks in advance .
If you set a morph target on the model immediately before you start sculpting with Layer, then Layer will sculpt to a constant depth above or below the original surface, regardless of how many strokes you use and whether or not they intersect.
http://www.pixologic.com/docs/index.php/Layer_Brush
You need to turn symmetry off.
wow, nice information! thanks for sharing!
