Problem with texture/skin
Hi, I am pretty new to zbrush and I am sculpting a self portrait but I am having some problems getting the texture to go on correctly.
I have attached an image that shows the problem. For some reason I can only paint on the brown areas. And when I change the material color it only changes the color of the light area. I have no idea why it is doing this or when it started since when I have the material color set as red it appears to be one solid color and that is how I have been working up to this point.
Thanks
Ok, I have narrowed it down to my material channel. I apperently drew on the model with the material channel selected. Now if anybody knows how to erase that I would be very thankful.
I will be goofing around to see if I can find it.
Ok, I just colored over it with a solid color and I guess that will have to do.
With Draw>M active, select the Flat Color material and press Color>Fill Object.
