sh…
i added hair obj using subtool to face…
Now problem is i polypainted the face… but hair i have texture…
when i add texture to hair thing in subtool the face also gets textured by current file…
please help me fix that.
thanks
In ZBrush 3.1 the same texture is applied to all subtools as only one texture can be displayed at a time. There are two possible solutions:
- Convert the texture to polypaint for the subtool:
- select the subtool that has the texture applied.
- go to the top subdivision level.
- make sure RGB Intensity is 100 and press Tool:Texture:Txr>Col.
Note that the subtool will need a high enough polygon density to keep texture detail.
- Alternatively, UVs can be disabled for all the other subtools; they then won’t display the selected texture. However, note that UVs will be lost with this method.
HTH,
thanks a lot!
