Hi
i have a problem with saving the project file , when i save the project and then i try to open it but the file is empty , the lighting and materials is there but the mesh with subtools is missing …
pls help
Hi
pls help
How are you saving a Project file and what extension does it have?
i go to - file / save as / 9.zpr
the name of my project is 9
i thing the problem is from the numbers naming of the subtools there must not be 1, 2, 3, 4… 9 … 0
because now i was rename my soobtool and try to save the file with the name for example test.zpr and the project file with tools is apperase now
the soobtools must have some name not only figure numbers ?
it’s this make sens ?
Thanks for the information.
I’ve not heard of this issue but if it’s causing you problems avoid using just numbers. I’ll make a note of this and do some tests.
Thanks marcus
i really like the new BPR render but i notice this problmes can you help me with this ?
the big problem is :how to avoid the lighning on the front parts of the face when i have enable backlights ?
and how to fix the problem - the shadows dominates on the lightning ?
http://www.zbrushcentral.com/showthread.php?p=719765#post719765
I’m not up to speed on the BPR so I don’t know why these issues are happening. I’ll take a look and see if I can solve the issue.
