Problem with normal map
Hello guys I have problem with normal map when i texture the model it looks like they have a lot of bumps over model please sorry for my English
Hi, it is probably image compression or the program you are using is not reading your normal maps as normal map. Which program are you using?
If it is blender, on the normal map texture, there is a option to turn texture as Normal Map
I create normal maps from zbrush and explored it in Maya
ok, there is also an option for that, if you are on attribute editor, on bump2d settings, the use as you can change to tangent space… instead of bump… that will probably work…
