problem with move and scale tool in 3.5
when using my scale and move buttons I get trailing artifacts and sometimes the machine just freezes up. any suggestions , any help ? my machine does meet the specs .
The trailing artifacts issue seems to occur on some graphics cards.
I get it on my office machine, but not at home.
About all you can do is make sure your GPU drivers are up to date.
Ctrl-N is useful to clear the mess.
The freeze sounds more serious. Can you pin down what you are doing
to make it freeze up?
G.
Hey there,
the artifacting is actually related to those buttons. Don’t ask me why but when you use the alt key for the navigation you won’t see any trails.
So just use the alt key for your navigation (it’s the better way anyway) and you should be fine.
Hope that helps
I stopped using the keys and it works ok so far . it’s annoying though I have buttons but I’m not supposed to use them , Ive incorporated them into my work flow now I have to change . my video card is nvidia quadro fx 3450/4000 sdi . thanks guy’s that helped
