problem with mesh
hi,
i have a problem with my mesh after i used smart resym.
most of the body look ok but there are some parts that look like this on one side now:
or look this:
i tried to smooth it but i could get all of that away with just smoothing.
if i smooth it on lower level then i only loose some of the shapes and thats even worser.
if i resym again it just look bad in the same way again.
can anyone help me please? :cry:
Did you try working your way up thru the levels?
  1. Go to your lowest subdiv level - smart resym
  2. Go 1 level higher - smart resym again
  3. etc to your highest level
Also store a morph target at your highest subdiv before you start - if areas of the mesh distort you can selectively reset them using the morph brush.
i still couldnt get it away without loosing the teeths. :cry:
this is how it looks in lowpoly:
its only on one side after resym.
is that a bug?
