Hi all. i’m trying to use the function edgeloops in zbrush 4 r4 but it doesn’t work properly in any models (see attached file). Does anyone konws how can i solve this problem?
Alberto
Alberto
As it is, your question is kind of vague. Can you post a step by step proceedure that gets you to this point so we can see if we can recreate it?
hi zber2
i was just following the text of Eric Keller “introducing zbrush 4” (page 107). The image i posted is from a a simple polysphere. I opened the polysphere from the tools lightbox and i turned it back to the subdivision level 1 and pressing ctrl+shift keys i selected some poligons to add geometry with the edgeloops command and when i turned to the 3 subdivision level this was the result (image 2). I tried to apply the same procedure to the model of dragon head of Keller’s book and to another tool i modeled and i had the same problem…
alberto
