It occurs to me that there is actually a way to save out the canvas so you can reload it ok, but it involves a little work:
- When you want to save your work, select the MRGBZGrabber tool.
- In the Tool>Modifiers turn off Shaded RGB, Auto Crop and Both (so no option is on).
- Turn on MRGB so that material and color will be captured.
- Click outside the top left corner of the canvas and drag across to beyond the bottom right, so the whole canvas is captured. You can adjust the Document>Zoom to make this easier.
An alpha and a texture will be created and be selected in the Alpha and Texture palettes. Immediately save the MRGBZGrabber tool using the Tool>Save As button, giving it a meaningful name. The alpha and texture are automatically saved with the tool.
Save the Document also to save any lights, custom materials etc.
When you want to reload, load the Document, then load the MRGBZGrabber tool you saved through Lightbox or the Tool palette. The alpha and texture will appear in their respective palettes. Then:
- Press Alpha>Crop And Fill.
- Turn off Texture>Cd (so depth is not cleared) then press Texture>Crop And Fill.
HTH,
