Problem symmetry from XSI to Zbrush
I have a problem with the symmetry in zbrush…
I created a base mesh in xsi, the model in xsi was centered perfectly symmetric, but when I import the obj exported from softimage in Zbrush all the pieces are out of symmetry, I don’t understand why, obviously when I use local symmetry I can work on both side of the mesh but if I want to mirror and wield a part that is only an half the mesh are symmetrized based on the scene symmetry so it doesn’t work well…
Is there a way to fix this without changing the symmetry in xsi to let it be good in zbrush? I’m using softimage SP1 2013 for 64 bit and Zbrush 4R4.
I have this problem only sometimes but restarting doesn’t fix the problem on the same model
Have you frozen all of your transforms in XSI?
Can you post a picture of the problem?
Does your mesh come in symmetrical in other software?
