Problem switching to material to paint with
I am attempting to paint only a small part of my model with a certain material. I chose the base material and filled the object, but when I switch to the material I wish to paint with, the second material is applied to the entire model.
Is there a step I am missing? Does anyone know why this is happening?
Thank you.
You have to select the M to the right of rotate so the fill object will use the material.
I did that, and it did not work
  1. Select your base color and material
  2. Turn Mrgb button on.
  3. Go to Color menu and click FillObject.
You can now select a different material to paint with. If you will be using a different color and material to paint with, Mrgb has to be on for painting.
