I’ve installed the ZBrush in D: drive
but the folder named “User” appear in C: drive
How can I put it in D: drive
thank you
ZBrush itself can be installed on any drive you wish. However, GoZ requires the C drive. This is something that is currently hard-coded into both ZBrush and the target applications.
So you can install ZBrush on any drive and it will work just fine. But for GoZ to work you must have a C drive, which is where GoZ sets up its user files to be able to communicate between ZBrush and other applications.
