problem mergeng subtools and post dynamesh
Let’s see if I can convey the sad problem with my English. I’m modeling this horny, but is causing me a headache, I did sculpt the body, and I thinkI did a extract to get the dress that in a future will be a nurse robe.
the point is I want to melt the bottom, instead of two legs which is what I have now, I want it shaped skirt. What you see between the legs in the first photo is a cube shaped to break the cylindrical shape of the two legs, but that the profile of the hips is maintained to look like the garment tight as possible.
in the second photo I merged the two subtools, the suit and the sculpted cube and if I apply a DynaMesh with these parameters in the photo and the mesh divided into 2 separate polygroups are intuited, the above poligroup appears full of holes, and the other appears ok right below. if I do it in one polygroup the holes appear all around the mesh.
I’ve tried to export and import the maya and merge points when importing, with bad results.
I’m a little stuck, any ideas?
thank you!
