Problem if double click Alphas...
Hi, im Sam from Switzerland (sorry, but my English is not so good).
I’ve buy zBrush from 2Weeks. Now, i learn the Interface and Commands. But one little Problem i’ve found:
I’ve downloadet from here Alpha’s. But if i double click now an Alpha, in the Alphas-Lightbox-Window, the most Alphas (some works with double click) don’t let see self then in the Alpha-Box, why?? Why some Alphas let see self on the Alpha-Box by double Click and why some Alphas let see self in the Texture-Box by double Click (yeah in the Texture-Box)?
Here, see this Image for better help, what i mean:
http://s7.directupload.net/images/131222/ueuooei5.jpg
Quite the UI… I offer you mine. I tend to use the right click menu.> It’s purple, save your colors before loading mine> http://www.zbrushcentral.com/attachment.php?attachmentid=386989&d=1386446536
You’ll need the Axis plug from here>> http://www.zbrushcentral.com/showthread.php?161588-quot-Axis-quot-Plugin-for-ZBrush-4r2
As to alphas>> http://docs.pixologic.com/reference-guide/alpha/
Ooookkkk… I don’t sure, to have understood you, what you have want say me.
It’s right: You say:
1.) You offer me your UI (and i just must change the Colors of this UI, your UI)?
2.) See *EDIT
3.) This Tool is just for rotate the Axis? Very Cool Tool. That i’ve never seen befor. Cool feature. Thx :+1:
Have I understood everything what you said?
*EDIT
AAAH, ok, sorry,… i think now i have understood:
2.) is: I must import the Alphas better from the Alphas-Menü (to find an the top on zBrush - The Menüs up on zBrush). Yeah, yeah… i think to understood.
Tthanks a lot, for help me… I’m now very Happy … Cooooool… :smiley:
*EDIT 2
Wuauuh! Cool, now works the Alphas. I’ve now all my Alphas in the Alpha-Box… Thanks a lot once more… :smiley:
It snaps camera views as per buttons, very cool. Some of the buttons in my UI are duplicated. If you hit Tab to hide some things you’ll see why. I don’t use too many brushes. Changed it a lot since I started to make it, trying to concentrate on artwork now :wink:
Yeah, very cool Feature.
I also in real don’t need so much brushes. But i love to set the most important brushes on my UI in logic order, to take fast, if need for an emergency. This is my Style of Interfaces. Also in Photoshop. It’s a little too full. But i love this so. :smiley:
Your alpha files must be 16 bit grayscale to be automatically loaded into the Alpha palette. If they are 8 bit per channel then they’ll be loaded into the Texture palette. This is because 8 bit images are not high enough quality to be used as alphas.
Ah, ok, thx for this great information. That i don’t have know… but good to know for future. thx again…:smiley:
