Problem following Zbrush Props by Pixolator
Perhaps it is a problem of the version since I don’t know for what version these samples were wrote. For example, I’m following this one:
And then the program crashes and closes itself. I tried the other blade types and always, when I try to apply deformation onto these pieces, I end up with an “explosion” of polys, then the programs hangs and crashes.
I tried to bypass this by not applying the step 3 (set HDivide= 128 / VDivide= 128). It still doesn’t apply properly when I apply step 4 but at least it doesn’t crash, but the problem is the same: the program is unable to apply deformation upon this particular tool :frowning:
Can someone try to do this and see if there is a way to sort out this problem and prevent the program to crash and apply the deformations properly on them?
You can check the rest of the tutorials here http://www.3dlinks.com/oldsite/tutorials_ZBlades.cfm but just if you want to try other kind of settings. Myself, I can’t get pass the step 4 due to the my problem stated above, no matter what kind of blade I want to try to make :cry:
It worked without any problems. I attached the tool. :wink:
I don`t know why it is not working for you. Which version are you using?
See here:
http://www.zbrushcentral.com/showthread.php?t=60857&highlight=deformation
Try what aurick said in post#3.
PS: I`m using Zbrush 3.5 R3.
