Problem creating ZSpheres with ZB3.1
i don’t often use ZSpheres in ZBrush 3.1 because it’s always a pain and i still can’t really understand how they are working…
Anyways i gave it a new try today but right at the beginning, i had my first problem.
After creating the first Zsphere, i created a second one on top of it, but after that i can’t move or rotate my Zsphere-object anymore. Every time i click on a free space on the canvas to rotate my object, he immidiately creates a new zsphere. F-Button to bring the object in the middle isn’t working after that anymore too, the F-Button now does the same like CTRL+Z or the UNDO-button.
What i am doing wrong?
Thanks in advance!
In order to move scale or rotate the ZSpheres, you need to either press “W” for Move, “E” for Scale or “R” for Rotate. As long, as you are in draw mode, you can only add or subtract ZSpheres.
Hope that helps
I want to rotate the whole Zsphere Object in Draw mode, not move or rotate a single Zsphere. But thats not working…
Well the only alternative is while in move or rotate mode hold “Alt” and pick the connection between the first and second ZSphere to move or rotate.
… und hi auch Landsmann :smiley:
Hope that helps.
