Probems exporting OBJ from ZB 3.5R3
I have read and talked to a few people about this and hope someone may be able to help.
What I have found is if I do any actual scaling of an OBJ inside ZB 3.5R3, I have problems with the mesh when exporting. The problem is the mesh totally messed up even though there are no errors when importing it into the program.
I was trying to do this with a Poser/Daz mesh and if you do any actual scaling on it in ZB and then try exporting, it simply goofs up the mesh no matter what I seem to try. NOTE: If I simply import an OBJ and zoom without changing the actual scale and export it works fine. It is ONLY when you actually scale the mesh OBJ this happens like with using the Action Line tool to scale the model.
A few others have said they have seen this too when working on OBJ mesh and using programs like 3DMax and Maya as well. They told me it was an export issue with ZB 3.5R3 and not just me having a problem like this.
So, does anyone know what is going on for sure and if there is any way to fix this or is it a real bug in 3.5 R3?
Thanks for any help or information.
