Hi
The issue I am struggling with is the scale function on the 3D printing export plugin.
I have set my scene in maya to mm and have modeled to the exact scale I want to print. (Its a piece of jewelry, a ring).
I export to zbrush to add high rez details then save as ztl.
Then I decimate the tool in prepiration to export as STL binary.
Here is the issue the printing export plugin gives you the option of “update size ratios” either inch or mm.
I have tried setting it to mm and updating and also (with a fresh zbrush open) not touching this option but the problem still arises of the STL file being way too big or small (depending on the settings in maya)
But I cannot get it to export at the correct scale that I imported it in as.
The sliders for width, height and depth are confusing as they seem to be constrained proportions.
Any suggestions on a work around or worflow would be appreciated.
Cheers
