Hey ZBrush helpers,
Just wondering if there is any way to preserve the background color when creating a new document. For instance, upon opening ZBrush I have my background color set to a bright gray with a very mild gradient. However when I press ctrl+N to start a new document, my background color resets to the UI layouts default color (in this case a much darker gray). Is there any way to make it so that creating a new document will use my saved Startup BG color?
Second question. I am using someone else’s custom UI and every ZTool I open now loads with a reflection material. However, I’d rather have MatCap gray. How can I reset my default material for loading ZTool’s?
Thanks so much in advance,
Eric
