Post&questions
Hi it’s been while since i’ve discovered “ZBRUSH”, and i’m still learning…but since i’m an outsider of “3D” and digital sculpting, i will benefit from this situation to ask some questions, because i don’t know how to search with proper “3D jargon”…here are the following:
1-Can i transpose without merging the subtools
2-How can assign different material to a polygroup or to a subtool( i don’t know how)
3-Can i make a copy of a stroke so i can repeat this sroke on a surface( i’m making my own alpha(on “Photoshop”)…but if i want a more complex sculpture…maybe i can repeat my stroke)
I know it’s wird question…so thanks for any answer or help or link! and this a post of a…if u can call that a W.I.P LOL! wip.jpg
  1. Try the Transpose Master plugin
  2. you can isolate the groups and then polypaint them with different materials (MRGB), for subtools, you can select them and then go to Color->Fill Object
  3. I’m not exactly sure what you mean. There is a repeat stroke function which repeats a stroke in the exact same place (making it stronger), but I think you are looking for a function like grab alpha: You can sculpt a detailed pattern and then use Alpha->GrabDoc to make an Alpha out of it.
Oh 10Q very much! it’s working(i’m lazy i should think to hold control from time to time) anwz that’s whath i needed to know! 10Ks man!Really!:wink: ! Cu around! hope also to see your work!cheers!
