Position Question? (answered)
i am working on sward.
i want to put some red stones on it.
when i see from left side position of small red sphere is okey…
But top view not correct …
Please help me …How can i solve???
http://www.doganerdal.com/s1.jpg
http://www.doganerdal.com/s2.jpg
Your server is very slow. It is better if you upload your images here.
Original post by aurick
Uploading Images is Easy!
To upload an image, simply click the “Upload Image or File” button, found under the text composition box when you’re writing or editing a post. Then follow the instructions on-screen. If you’re using Internet Explorer, after the image has been uploaded you can simply click the link that you’ll see to insert it. The code for the image will appear at the your cursor’s position in the text composition box.
If you’re using FireFox, the insert link won’t work. Instead, look at the image list that will appear below the text composition box. You’ll see the image listed, along with a code that looks like:
{ATT=123456}ImageName.jpg{/ATT}
(You’ll actually see [ and ] brackets instead of { and }. I simply had to use the other brackets so that you could see the code.)
Simply type that same code into your post where you want the image to be. When you submit the post, ZBC will insert the image. (Do NOT copy and paste the code, or drag and drop it. Doing that will also copy javascript, creating an underlined link in the text editor. This will prevent your image from displaying when you submit your post.)
It really is that easy! And to help people out, we’ve even recently increased the allowed file size to 500k
the normals on your sphere are inverted.
tool>visiblity>flip…it might be in display instead.
i use zbrush 4
ş cant find…
Display Properties
Yesterday i said that i solved zbrush % 93.
Today i say % 94 :slight_smile:
Many thanks…
