posing with zspheres [Answered]
When I click preview button with shift unpressed I get a model with pose but without details. When I press shift while clicking I get a model with detail but without a pose. When I clicked make adaptive skin I get the same result.
I think it will only work if you Shift+click the Preview button before posing:
  1. Select a ZSphere.
  2. Press Tool>Rigging>Select Mesh at select the mesh you wish to rig. It should be at its lowest resolution.
  3. Create the ZSphere skeleton.
  4. Press Tool>Rigging>Bind Mesh.
  5. Set the Tool>Adaptive Skin>Density slider to the number of subdivision levels that the original mesh has.
  6. Shift+click the Tool>Adaptive Skin>Preview button. This will preview the high res mesh.
  7. IMPORTANT: make a very small sculpting mark somewhere on the model. This is essential for ZBrush to record the high res detail.
  8. Unpress Tool>Adaptive Skin>Preview.
  9. Pose your model.
  10. To preview the high res version, simply press the Tool>Adaptive Skin>Preview button (no need to hold Shift).
Thank’s.My model was broken. I load the previous version that I saved and everything was ok
