Hi all, how do you transpose a model with subtools? When I try to edit the position of the main mesh the subtools don’t move with it, is there a way to affect all when transposing?
Thanks!
Thanks!
Yep – There´s an easy way
: Transpose Master Plugin
Infos:
http://www.zbrushcentral.com/zbc/showthread.php?p=417808
Download:
http://www.pixologic.com/zbrush/downloadcenter/zplugins/
Installed it, read the instructions, the result is:
Help…
You can only make limited use of topological masking with Transpose Master. The TPose combined mesh is composed of separate geometry in a single mesh. So mask using the lasso mask instead. In your image the teeth etc. have become masked which is why they were left behind.
HTH,
