Poser scaler (import) for ZB4?
Is there a solution for importing Poser obj files for zBrush 4?
I see the plugin for version 3 but not 4?
Thx
The scale issues don’t occur in ZBrush 4. After import you need to note down the value in the Tool>Export>Scale slider so you can check that it’s the same when you are ready to export. Otherwise all should be good.
Thanks Marcus.
