Poser Import is now included with ZB 3.5?
Poser Import is included with ZB 3.5, so where the heck is it? I’ve looked under every stone in this program and can not find where it is.
I don’t even see an accessible help file within ZBrush!! If there is I can’t find that either.
Thanks for the help
The wording on the Downloads page is misleading; Poser Scaler is no longer necessary with ZBrush 3.5 as importing/exporting directly is now much more accurate.
For general help information see the PDF installed along with the program or the online documentation:
http://www.pixologic.com/docs/index.php/What's_New_in_ZBrush_3.5
Thanks for the reply.
So to import I would use the Import function under the Tools palate? And then to export, Export function? My concern is that in order to get a Poser obj to look good in ZBrush it needs to be scaled up and then back down to the proper size in order to get it back into Poser or DAZ Studio so things like morphs can be properly applied and added to the main figure in the scene.
Thanks
The scaling is no longer necessary. Simply import and export with the default settings. (The point of scaling up/down in earlier versions was because ZBrush didn’t handle the very small Poser figures accurately enough but this is no longer the case.)
