Hello, noobish question here.
Does anyone know what button “Popup” for some shortcuts is?
I have tried to set my Standard Brush shortcut to Alt+S but to no avail, since the default shortcut for Standard Brush is “Popup+T”.
I have pressed B and T consequently and at the same time, but it didn’t show the Standard Brush.
I also have changed the StartUpHotkeys.TXT for the Standard Brush from Popup+T to Alt+S to no effect.
B for the brush menu followed by S and then T should load the Standard brush.
To set a hotkey for a brush:
- First select the brush so that it appears at the top of the Brush palette.
- Ctrl+Alt+click on the small thumbnail of the brush in the Brush palette.
- Press the hotkey you want to use.
