Hello,
It’s been awhile since I’ve used ZBrush to Polypaint via Spotlight. I Haven’t done so since my upgrade to 4r5. My problem is that I’m trying to Polypaint a 3d model exported from Poser. I’ve done all the steps correctly and was satisfied with my results until I went to the texture pallette to click “New from Polyaint” and discovered that it wasn’t there. All I see is “New Texture” and the rest are grayed out. So, has something changed since the upgrade? Need help with this. Thanks.
You object will need to have UVs before that option will be available.
Thanks forl the response. UV’s? I exported the mesh from Poser via “Export to Zbrush” option. The material should have been in the export. Correct me If I am wrong on this.
