Polypainting question
Just a quick question on polypainting. I have painted a model in high rez. Sub D level 7. Texture looks good. I want to create a texture from polypaint. So I create a texture 6000x6000. That is the size I want it. Then I go and choose it in my tools = texture map = and then I click new from polypaint. But my texture that is created is only 2048x2048 pixels. How do I get a custom texture size?
Thanks
Joey
which version of Z are you using?
the way you make a texture is different in 3.5
tool>UV>map size. There are buttons for 512-4096. You can also set a specific size there as well.
Once you tell it the size of the map then you can go to texture>new from polypaint.
hope that helps.
Thanks goast666
Works like a charm.
:slight_smile:
J
