polypaint with matcap problem
Hello,
Im pretty new to zbrush and have only done a few sculpts with it.
I wanted to try and polypaint a new model but i wanted to use a nice skin
matcap as my base color.
Problem is i get this http://img72.imageshack.us/my.php?image=dotsqt5.jpg
when i have colorize on.
I want to remove all color and start again with a standard material or matcap
but im lost on what to do.
I dont understand what is causing this dotted look.
color>fill object (white probably)
Thanks for the reply but i tryed that…no luck.
I might have to send my tool to a friend to look at.
cheers
Select white color and also the FlatColor material. Make sure that Draw>Mrgb is turned on. Then press Color>Fill Object. This will reset the figure.
