Polypaint with layers issues
Is it me or has anyone else experienced problems with layers and Polypaint?
A problem occurred for me when I tried to create a texture from Polypaint when some of my painting was on separate layers. I’ve attached an image of some simple painting on a sphere and a couple of the results I get when I try to create a texture from Polypaint. It doesn’t seem to make any difference if I bake all layers beforehand… Wouldn’t it be great if you could paint in layers and then create individual textures of each layer!
looks to me like you are trying to make a texture with an un-wrapped object. Have you laid-out the UV’s on your object?
You might be right. I tried this initially a default polysphere which already had UVs, but I deleted them and unwrapped with UV master and it seemed to work… my fault.
thanks
