Im relatively new to Zbrush as a whole and have been following various tutorials. I’m trying to use polypaint on my mesh but on the first step of the process, being “fillobject”, to fill the mesh with one specific color, I’m stuck. My mesh does not change at all, no fill, no color change. I’m not sure exactly what I’m doing wrong, any help is greatly appreciated!
Select the subtool you want filled.
Turn on ‘Mrgb’ button.
Select your material and color.
Go to ‘Color’ menu and click ‘FillObject’.
‘Rgb’ button will fill with color only.
‘M’ button will fill with material only.
‘Mrgb’ button fills with both material and color.
Make sure your active brush has rgb or mrgb selected and increase the intensity to whatever you decide. 100% will completely fill it, and any number lower than that will be less (kind of like opacity levels).
