import obj with UV
import texture map
apply skin shader
texture is displaying correctly
polypaint from texture
model is solid red
any suggestions?
import obj with UV
import texture map
apply skin shader
model is solid red
any suggestions?
hi @magilla,
Please check the subtool in Tool :: Polypaint, does the Colorize button enabled ?
also make sure the texturemap is off after appling the texture to polypaint, it should turn it off automatically.
Hope it help
Nicolas
turned out to be the mrgb mode not being on - d’oh!
