Polypaint from Mask
Hi there,
I have an issue. I wanted to make polypaint (or texture) out of a mask, but what I got is pure black with some hints of white…Is there any specific workflow, guys?
Cheers
Jester
I get this too. It doesn’t appear to be functioning correctly at present, unless there’s been a change in how this process works that I’m unaware of.
Lots of work arounds though. You can always invert the mask on your object, then, with polypaint active go to color>fill object, and fill the object with the color you want. Only your original masked shape will be filled, and then you can make a texture from that.
