Polypaint changing on marquee selection
Hey there folks, I have this odd problem in zBrush at the moment. I have a scanned .obj that I’m polypainting and when I use the selection it goes all… funny.
Here’s a picture to help explain.
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
Grateful for any help!
See here for help with uploading images to ZBC: http://www.zbrushcentral.com/showthread.php?t=94904
By chance, are you using layers? There is a known issue that when you partially hide a model that has multiple layers, polypaint on other layers gets jumbled. This is simply a rendering issue, though. When you unhide the polys again the display of the other layers returns to normal.
The current layer in this case is not affected. So you can polypaint on it without trouble; just ignore what’s going on with the other layers!
Thanks very much! That was indeed the case. Cheers dude.
