Polygroups from Uvs bleed?
Hi all, first question here :slight_smile:
I import my mesh from max and use Auto Groups from Uv to create polygroups. It work fine, but as soon as I subdivide the mesh, the polygroups “bleeds”. It is noticable because I have sharp edges and after a few subdivision it is unusable because it does not define the area I wanted anymore.
Any tips or help to solve this?
Thank you in advance
Could you show what’s happening? It’s hard to figure out from the description. Thanks!
Sure thanks.
Here is the mesh imported and I used autogroup from Uvs in the polygroup menu. All fine.
cheers
PS: btw the upload image does not work at all in Firefox, as there is no ATT number in the code below the message.
