Polygon data Mismatch - Transpose
I’ve crawled the forums looking for a solution to my problem and the last time someone had this problem was back in 2007 and there was no visible answer as to how to fix this problem.
I have my zSphere Rig built, character posed (my original mesh is multi-subtool) and when I go to “Tpose>SubT” I get this error:
“Polygon data mismatch - SubTool Project1_06 skipped”
How was the polygon data messed with in the first place? I was messing with my rig, not my mesh, so I don’t understand how I’m getting this error in the first place.
Help?
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
zbrush can’t do a “_” when transpose master makes your new meshes, it inserts a “-” in its place. So when it tries to put the mesh back it can’t find it.
Remove the underscore in your file name and you should be fine.
What an odd Error Message for something related to naming convention and not polygons (geometry).
Is there a way to save the rig and still save my multiple subtool sculpt?
Not quite sure what you’re asking with that one.
