Point select not working in Z4?
I can’t seem to make point select work in Z4. I sure hope I’m just doing something wrong, because I use this feature ALOT! Is it just me or are others having this problem?
Upon further research, I’ve discovered that point select NEVER works (whether the button is on or off) when selecting polys (the green area), but point select is ALWAYS active when de-selecting polys (the red selection area). I hope they fix this.
I am having the same problem, also when I ctrl + shift select an area and release shift I do not get a red area to remove polys, is this all part of the same thing. Surely everyone uses this method so I thought there would be a lot more about it here.
Cheers !
CTRL+SHIFT AND ALT GIVE YOU THE RED AREA
