hello all … i am new here and just wanna know how to save a final look of the object after adding colour and everything so as to use in other programs ?! … thnx in advance
I’d like to help, but please…be a little more specific about what your problem is.
For instance, what do you mean with “everything” and which are the “other programs”?
first of all thnx for ur fast reply :o)
now i am new to the program and the 3d work as a whole … so i would like to know how :
1 . save a complete model with colours and texture and look and return back to it when i need it to add on it more ( like colour or even masks )
2 . what programs can i use to make a movie using models and objects from zbrush … and how to get to do so …
- what’s the difference between an object and a tool … and
thnx again
first of all … thnx for the fast reply
i am new to zbrush and also to all the 3d stuff and so i would like to know :
1 . how to save a model wiz the colour and material that i want and to be able to return back to it to change anything i want . ??!
2 . what is the programs that i can use to make a movie using objects or models made by zbrush ? … and how can i do that ?
- what’s the difference between obj and tool
thnx again
1) Tool>Save As.
Any animation package that supports the OBJ format will work. Maya, Cinema 4D, 3ds Max, LightWave, Softimage|XSI and more. Every one is different, so you’re going to need to do some research – not only to figure out which is best for you, but then how to use it to do what you want.
OBJ is a file format for 3D models. It’s what you get when you export your model from ZBrush. When you import an OBJ into ZBrush, it becomes a Tool. But ZBrush has many, many different forms of Tools of which 3D polymesh models are only a subset.
I recommend that you spend some time at the ZClassroom and the online documentation for ZBrush. You’ll learn a lot of basic info quickly, which will help you. The links are in my signature.
