plz help(zBrush4 Goz with maya 2011)
when i try to move my mesh zbrush to maya maya window is opening and it says file not found. İf i try to move my mesh maya to z brush, zbrush opens a new tool but there is no mesh in my view. at the first it was working. normal maps uv data everything goz to maya right but now i cant even see a mesh. i cant say any specific problem because i cant get any error or something. plz help. thanx
+1
after try too many combinations i figured out how to work with goz. The first thing to remember, you have send your mesh z brush to maya first. otherwise it is not working and maya says file not found. so when you open your mesh with zbrush before click goz you have to save you mesh to this directory
C:\Users\Public\Pixologic\GoZProjects\Default
as a ztl file.
After do this it is working like water and not causing any problem again. Of course you have to repeat the proccess every time you open zbrush and maya.
And other very important thing to remember when you are sending your mesh maya to zbrush that mesh must be parent of the world. otherwise when you open zbrush you cannot see any mesh file even it says uploaded right.(in my research to many people has this problem).
I know this not a solition. More like dealing with the problem. But for now it is working for me. i hope this helps the others… Any certain solitions are welcome of course
As I posted in another thread, I had the same exact issue, but after a clean reboot of my machine, I created a new mesh in ZB and then pressed GoZ from there. Maya 2011 opened and all is well with the world.
Anyway, hope this helps.
http://www.zbrushcentral.com/showthread.php?p=720121#post720121
