plz guys help me in maya ''Fatal Error: Attempting to save in.....
hi guys
i was working in maya 6 and i created an image plane and a window pop
and tell me
Fatal Error: Attempting to save in…
plz help me guys
If you are running Windows, Maya attempts to save your work on C:\windows emp. Just take a look there, organize the files by last modified, and you’ll see a ma or mb doc. Problably you’ll can open, maybe with some losts on your file.
no there isnt any mb file and i have seen someone writed the same prob and thev told him to disable triplle buffering but i diabled it and still when i open my mb file or when i create an imageplane give me the same message
please tell me what i need to do
My fault, Adam. The correct path is the one listed on your image c:\documents and settings\administrator\Local settings\Temp, the ma file must be there. Anyway, if you are having trouble with image planes, create a plane, with the image dimensions, and use the image as a texture, with a flat material, aplied on it. It’s more flexible than using image planes. You can put this plane on a reference layer, so it can’t be selected, and you can control wheter is visible or not. When i was learning and using Maya 6, I usually did this way.
thanks bro
